chadr
I was looking at a set of HT leads for the truck - the current set are the originals as far as I know and I thought I might replace them at the next service.
I haven't even bothered to ask Mr Toyota how much he wants for a set of OEM leads, however there seem to be quite a few other options available out there......
Apparently the OEM leads are made from 5mm or 4mm cable....and you can get similar spec items for around £30 for a 3 lead set. Then you have various "upgrade" spec leads at higher prices, I've listed a few examples below from one supplier to give you a flavour;
7mm version - £66 for a set of 3 leads
http://www.dcperformance.co.uk/uprated/magnecor-7mm-ignition-leads/toyota/landcruiser.html
8mm version - £68 for a set of 3 leads
http://www.dcperformance.co.uk/uprated/magnecor-8mm-ignition-leads/toyota/landcruiser.html
8.5mm version - £82 for a set of 3 leads
http://www.dcperformance.co.uk/cheap/620373/toyota/magnecor-kv85-ignition-leads/mgn-65162.html
Using these examples, the cheapest upgrade is double the price of the OEM spec items and the "race spec" version nearly 3 times the price.
Firstly, is it worth "upgrading" the HT leads at all ? If so, then what am I looking for?
P.S. If you are going to bother and using the above examples, it makes sense to go with the 8mm version as it's only going to be £4 dearer than the 7mm......
