As I'm very new to recovery topic I would like to know how to connect a recovery hook to my ARB bumper so it's safe and correct. I found the following photos on the web but it look like your first photos in that it will put a lot of force on the pin.
Hi Marius, although quite pretty, I'm very disappointed with my ARB front bumper. The "tags" they provide for the high-lift are no more than that and despite being double thickness, they're way too flimsy, IMHO, for snatching.
A straight tow is all they're good for, but I wouldn't want to connect a kinetic to them.
As for Ben's idea of mounting a strop between them, the idea is good, but in practice they're so thin that they would pull together like a cross-eyed dog! I've mounted a piece of 4" RSJ across mine behind the front face and under the winch. It's welded all round and has extra triangular fillets which go through the front face and lay flat alongside/against the standard mounts. These have been cut to the same profile and drilled so now I have the standard mount with double the thickness and their attached to something decent, the RSJ.
I admit this may be overkill, but I'd bent those standard brackets so many times (on rocks and stuff) and bending them back was so easy by hand with a 12" length of gas pipe, which shows how flimsy they are.
I'm nowhere near as experienced as Chris when it comes to winching and snatching, but I've done a fair bit.
I'd recommend at the least to have some spreader plates mounted behind the flat front face of the bumper and some decent snatch mounts bolted through (or welded). These would have to be as close to the triangular strengthening fillets behind the front face, as possible. Even then I wouldn't be too sure that a decent snatch wouldn't do some damage to the ARB.
Sorry to sound negative, but I am very unimpressed by ARB's front bumper, the rear is much more sturdy. I suppose the front should be more of a shock absorbing unit than the rear needs to be, but in all honesty, it really is a joke. It rusted like fcuk as well in less than 2 years, I've had to have it completely refurbished and powder coated again.
Not impressed. Better still, why not bolt some custom made snatch mounts from the bumper mounts on the chassis. I know these are a pain when you're in deep mud, but at least you'll know they'll hold.
