fridayman
The steering on my Colorado has become increasingly vague. I have changed the fluid, fitted poly bushes and changed the rod ends. I haven't change the tie rod inners yet. I also know there is a very small leak at the steering column seal, but this doesn't even drip on the ground. The vague feeling is worst at slow speeds e.g. if I pull away from a standstill and do a 90 degree right turn, I turn the steering wheel between 270-360 degrees. While I can only move the steering wheel back and forth about 10% at 70mph, before the truck sways. The vague feeling is equal in both directions. The steering still feels very light btw.
Can anyone explain to me what has changed (from a new steering setup) to produce these symptoms?
