1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
very loud noise from the right rear side of the engine compartment
ScottT Jan 1, 2017
  1. ScottT
    ScottT New Member I am in united_states
    2
    0
    1
    Map
    Has anyone else ever experienced a very loud whirring noise coming from the right rear side of the engine compartment? it seems to only happen at highway speeds after the engine is warm. Taking it out of gear does not change the noise nor does slowing the RPM's. It doesnt seem to impact performance but obviously it's not a good thing. Anyone know what I have going on?
  2. StarCruiser
    8,165
    2,745
    113
    Garage:
    Map
    My first thought was the heater fan with something in it. Try turning it off and see what happens.
    Just a thought, I'm not familiar with your series of truck.
    Good luck finding it
    Richard
  3. Bungarra
    Bungarra New Member
    41
    14
    18
    Map
    Putting your gear box in neutral and the noise persists means you can rule out an engine problem.
    Sounds like a tyre ie, missing some tread or the tread has picked up something or a wheel bearing
    Both these things can be easily inspected by jacking up your front drivers side wheel. Give the wheel a shake and a spin to detect a bearing problem, or check the tread
    Good luck
    zodiac88 likes this.
Share This Page
