stuzbot
- Jan 20, 2021
This problem is so basic I'm almost embarrassed to post it. But...
As of the past couple of days, I just can't get my bonnet to latch properly when I close it. I'll admit I've only had the bonnet open a few times before, given I've not had the motor that long. But never noticed anything odd about it before.
This week however, I've done a couple of days working on the truck and, both times, I've had a hell of a job getting the bonnet to close properly afterwards. In fact I've not been able to get it to latch at all today, so have just had to leave it semi-latched on the wee release lever. I've tried letting it down gently and pressing it, slamming it down and even jumping up there and sitting on the bonnet and bouncing up and down with my body weight on it. But it just won't catch.
As I say, it seems an embarrassingly prosaic thing to get stumped by, but stumped I am. I've looked under as the bonnet closes and everything seems to be lining up properly. And, even if they weren't, there doesn't seem to be any adjustment possible. My instinct is that I want to either raise the bottom catch a couple of mm or lower the hoop on the bonnet which locks into it a couple of mm, so they close together better. But, as I say, I can't see any adjustment possible.
Anyone run into this before or got any ideas what I can try next? It's going to be bloody embarrassing if, every time I lift the bonnet for some reason, I have to spend half an hour afterwards bouncing up and down on it, trying to get the fecker to close again.
Pics of my catch. Just on the off-chance someone can spot something amiss with it. I did wonder if it could be related to the fact, mentioned in another thread, that my front grille has been broken at some stage [circled, you can see the stump of one of its plastic brackets on the bonnet catch housing]. But the catch itself doesn't seem to be missing anything or bent out of alignment...
PS: The forum software has suggested this 'similar thread'. So, I'm glad to see I'm not the only one to have been flummoxed by e recalcitrant bonnet catch!
