Jureb
- Dec 29, 2020
I've got to change my ATF for the first time in my 95 prado. I'm only doing the regular change and not flushing or changing the filter. I don't know which ATF the previous owner used and I'm wondering which ATF is recommended. It came to my mind that maybe it's not the best to mix different ATFs. Maybe there's synthetic ATF or some other spec ATF in my autobox right now and I was thinking of putting Dexron III in it - as the manual says. Is mixing them inadvisable, since the majority of the old ATF will remain in the autobox after the change? Unless I do a full flush I have high chances I will mix 2 different ATF specs together.
Valvoline says mixing isn't bad: Car Fluid FAQs: Transmission Fluid, Oil - Valvoline™ Global - [Leaving Land Cruiser Club].
