Which axle have I bought ?
That would be awsome !
Please PM me your tel no and once i've contacted Chris, I / we'll be in touch
Cheers :thumbup:
Matt Richards said:
Thanks for the ratio info, I'll have to remove the callipers to turn the pinion as the pads are 'stuck' to the discs, i'll keep you posted.
Remember . . . .
If you can't lock the diff, then lock one hub.
Rotate the input flange a good number of times and count the number of hub rotations.
Then divide the hub rotations by 2 before calculating the input to output ratio.
If you can lock the diff, then both hubs will be turning together (= turns of the crownwheel) so no division is necessary before calculating the ratio.
You won't get a true figure with an open diff and both hubs free to move :naughty:
Sorry if this is "teaching Granny" :oops:
Bob.
