Paul said:Outer one on my 100 has done the same after the lift. Very old boot though, will be replacing all of them....well Greg will be![]()
fridayman said:My left outer boot, small side, keeps sliding up the axle and leaking grease. The CV angle after the lift probably has something to do with it. So I bought a replacement boot, but have to take the whole drive shaft out and remove the inner joint to replace it...![]()
I didn'tBIG clean GREEN said:How much grease did you put back in and which type did you use Steven ?
