Tractionman
- Oct 11, 2013
Yep, one way or the other !
I am planning this task for saturday. Now I got the itch of getting under the car and using some tools, also little more confident that I wont damage anything, i will be under it when ever I get timechange the diff oils
I cracked one of my ramps. This time I kept in low and reversed on to the ramp and while reversing and breaking suddenly, tyre went over slightly over and cracked one of them. I will replace a pair. These ramps are so good and easy to use.Those ramps look the same
it was a bad idea. its level ground, I used these ramps few times without problem so far. Car was parked close to steps in front of the door. I could ve reversed normally and arranged ramps at suitable distance from the steps but I thought i ll use low range in reverse and see how it feels. I went too much and about to drop off the ramp, then hold the break and drove little forward. Thats when it cracked.reverse up them?
