Kierencaldwell
- Aug 15, 2015
Just wired in a new reversing camera & monitor. Used the rear cigarette lighter as a wire in so it comes on when car is started. As camera was mounted on the rear of the roof rack this was the easiest set up. Engine warning light is now showing. Is this the ECU not being able to deal with the new wiring?? No dramas until this circuit added. Have previously wired a cb uhf from the front cigarette lighter accessories port in the same fashion with no problems. Thoughts would be appreciated??
