Well Guys Pics as promised.
First one all the IFS off apart from the Lower wish bones. Quick tip here if you are going to cut through the camber adjust bolts be careful not to have anything infront of them. They will pop and fire out at quite a rate of knots.
Well thats all of the IFS Bolt on components off. Not let the chopping commence.
Say goodbye to the front ARB brackets.
Then the rear crossmember for the lower control arm. I did wonder how much strength I would loose by cutting these away. Had a look under the 80 and there is nothing between the front cross member and the gearbox one. so that put my mind at rest a little. I might add one once the axle is in and i can see the clearances properly.
Then away with the front x-member for the IFS and everything is gone. Looks kinda naked under there.
Chassis all cleaned up. I have left the spring cup on for the moment just to give me an idea as the where the axle should sit in relation to the wheel arches. These will have to come off just not quite yet.
This is the bracket for the hocky sticks on the 80. Believe it or not the 90 chassis at this point is more than 100mm wider than the 80.This means that these mounts will sit on the inside of the rails.
These are the ones I have fabbed up.
Getting quite excited at the moment. Once these brackets are on that is a big leap. Nearly done I think. Well, Apart from......
upper spring cups
shock mounts
panard bracket
steering box
re-install gearbox
fabricate new exhaust
figure out locker wiring
hmmmm list not as long as I thought it was. whoop whoop
