- Mar 1, 2010
Hi Chaps
I have been through my 100 as far as I know and everything seems OK. However are there any weak points I should check out ?
It's a 4 sp auto with overdrive 2004 4.2 diesel with 64,000 miles. I've checked the suspension and steering column motors and they are OK. The aerial sometimes goes up with no command but I can live with that. I'm thrilled to bits with it. 1 previous owner who never did a trip of less than 10 miles.
The oil is crystal clear after 1200 miles. Is the filter different to the 80 one? When I change oil on my 80 I drain it hot and leave the plug out overnight but the oil is still a little black after this.
Frank
Frank
