Towpack
With respect, whilst your calculations are correct IF the 12 volt starter was 4.5kw however they are not.
The 12 volt unit for standard 80 is IIRC 2.5Kw i.e. 208.3 A
I use the 12 volt unit from the 100 series and this is 3.0Kw so 250 A
Note that Toyota reverted to the norm of 12 volt starting with the 100 using the same engine configuration as the 80, soooo........(Dave throws some more fuel on the fire )
regards
If this is true then that is probably the main reason why the engine cranks over quicker and starts almost instantaneously on 24V. A starter of almost twice the power rating must make a big difference. JMO
