stuzbot
- Jan 20, 2021
I'm know aspects of this have been mentioned in many a thread but, as I'm still questing manfully for my first Land Cruiser, I'm trying to collate the various snippets in one place.
First off, the 1KZ-TE versus D4D debate. From what I've gleaned so far:
1KZ-TE
* Mechanically simpler = easier for DIY spannering & cheaper parts but mechanical pump likely to be worn at this age
* Cooling system needs to have been well maintained or cracked heads and strawberry milkshake auto boxes can ensue
* Otherwise pretty bullet proof
D4D
* More complex. More to go wrong. Not so DIY friendly
* Better fuel economy & performance
* Injector seal issues with earlier models [years?]
Anybody got anything more to add to that? I'm minded more towards a 1KZ-TE, just because I'm an old curmudgeon who likes to work on my own motors and am a bit dubious about too much electrical jiggery-pokery in an engine. So relative mechanical simplicity is a big factor in favour of the 1KZ-TE. Then again, being a newer engine, a D4D would theoretically be less worn, so might be less likely to need me to get the spanners out. And I'd get better performance and fuel economy.
The head cracking issues with the 1KZ-TE do concern me though. I've read the epic thread on that...
...a couple of times and the situation seems to be preventable with a bit of attention to the cooling system and fitting of a more precise coolant temp gauge.
If I got a 1KZ-TE I'd likely fit a separate transmission oil cooler anyway, as well as flushing the cooling system and refilling the viscous fan. But, obviously, buying a 20+ year old truck, you don't know if it's been well looked after before you got it. I know to look for sludge round the radiator cap, listen for bubbling from the heater, look for strawberry milkshake trans fluid, etc. But an unscrupulous seller who's aware of these issues could change those fluids and clean up the evidence. Any other tips for spotting evidence of head problems or transmission fluid contamination while doing a pre-purchase inspection?
Then the 90 Series vs LC4 debate:
I was quite surprised, when getting insurance quotes to find that [exorbitant though they all were] it wouldn't actually cost me that much more to insure a mid 2000s LC4 than to insure a late 90s J90. [BTW I'm specifically saying LC4 as opposed to LC3 or LC5 as that seems to hit the sweet spot as regards extras, but without the overly complex air suspension system]. So I'm wondering if anyone has any opinions on that particular choice? I know this is the 90 section of the forum, so expecting a bit of bias. But I would be interested in honest opinions as to how the LC4 stacks up against the 90 series?
I should say that my use case for my Land Cruiser would be every day driver most of the time. Not really used that much though. Maybe a couple of shopping missions a week. But, away from the day-to-day missions, I'd be using it for lots of wild camping trips [mostly round UK and Ireland] and also I have several friends who live at opposite ends of the country. So a fair few long motorway journeys to visit them. So, while I'm reasonably mechanically competent and don't mind getting my paws oily when required, I'd much rather that be in the pursuit of adding improvements to an already reliable vehicle, rather than spending that time and money trying to keep a vehicle reliable in the first place. Which is why I have slight concerns about the 1KZ-TE as I'm already thinking I might have to budget a few hundred £££ to bullet-proof the cooling system if I got one of those, which would buy a nice set of new tyres for a newer model, where that wasn't an issue.
Hmmm... Decisions! Decisions!
1KZ-TE
D4D
Cooling the 1KZ-TE motor:
Evenin' All. As many of you will know, I use my 1998 KZJ95 UK-spec Colorado for towing a double horse trailer. When I bought it, I expected the 3.0 litre 1KZ-TE turbo diesel to be well up to the job of pulling around two tons with four or five occupants plus equipment. The reality has been...
www.landcruiserclub.net
