- Nov 19, 2010
Just wondered if anyone can shed some light in this.
A pal of mine brought his 09 plate 200 series round yesterday to see if I could shed any light on a problem he has with it.
Basically it pulls to the left as it is being driven. It has had 4 new tyres fitted (dunlop grandtreks, OEM) He had the tracking checked at the same time and the pressures are correct. The tracking was set to "0" which I assume means parallel??
It pulls to the left more than the action of the road camber and if you take it to the RHS of the road it pulls back to the LHS if you let go of the steering wheel.
I have had it on the ramp and there is nothing obvious worn, bent or damaged (26K miles) and only driven on the road.
Does anyone have any ideas as to the setting the tracking should be from the factory or is there a "rule of thumb" with permanent 4WD's
Andy
Andy
