These are the airbag helper springs aren’t they Karl?
StarCruiser Well-Known Member Supporter Guru Joined Oct 7, 2014 Messages 12,047 Garage Country Flag Mar 25, 2019 #21 These are the airbag helper springs aren’t they Karl?
karl webster Well-Known Member Supporter Guru Joined May 20, 2010 Messages 5,808 Mar 25, 2019 #22 yes rich. photo on the first page.
grantw Well-Known Member Supporter Joined Jul 15, 2012 Messages 2,178 Mar 26, 2019 #23 Karl - do you have a set for a 2" lift?
karl webster Well-Known Member Supporter Guru Joined May 20, 2010 Messages 5,808 Mar 26, 2019 #24 i can get some grant if you want to send me the length you need
grantw Well-Known Member Supporter Joined Jul 15, 2012 Messages 2,178 Mar 26, 2019 #25 I'm not sure how to measure .. I have a 45mm lift on with iron man pro springs.
StarCruiser Well-Known Member Supporter Guru Joined Oct 7, 2014 Messages 12,047 Garage Country Flag Mar 26, 2019 #26 grantw said: I'm not sure how to measure .. I have a 45mm lift on with iron man pro springs. Click to expand... 45mm spacer?
grantw Well-Known Member Supporter Joined Jul 15, 2012 Messages 2,178 Mar 26, 2019 #27 StarCruiser said: 45mm spacer? Click to expand... No, that is just the lift height quotes on their specs. The iron man 2” lift is nowhere as big as the EFS one ... which seems to be closer to 3”
ADD Active Member Supporter Joined Jan 25, 2019 Messages 82 Country Flag Jul 17, 2019 #28 Has anyone done a complete replacement for rear springs with airbags not just the helper bags? https://forum.ih8mud.com/threads/an-au-epistle-for-overweight-lx-470s-lcs-with-ahc-part-1.94903/
