105Aus
- Dec 30, 2014
Started work on fitting my new found ARB Deluxe bar yesterday after work.
Here's my old bull bar on the front of my car, was abit painful to get off, it's obviuosly been off before as a few of the bolts were different types and had different heads on them, and whoever tightened it up snapped one of the tack welded nuts from the chassis rails so I had to use a pry bar to put pressure on the bolt/nut to undo it.
Here's a picture without a bullbar. My chassis rails at the very front were clogged up 80% of the height of the rail with old mud and sand, I always flush my chassis rails after off roading to try and avoid build up but with the bar mount ends being capped and the nearest chassis hole back half a foot there was no way to tell it was there or remove it.
While i have no bar i'll be painting the strip panel that goes under the grill and headlights. The old bullbar had hard rubber mounted ontop to take up the gap from bullbar to panel work and over the years its rubbed a lot of the bottom of the panel back to bare metal.
I've sanded it back ready for some primer and filler primer, then ill paint her up and polish it back and should be set to fit the new bar on in the next 2 days.
Also have to try and cut my uhf aerial bracket to free the aerial, as the bracket had 1 nut that wasnt stainless and its caused the stainless steel bracket to cop some rust, i'll polish it back and paint it mat black to blend in with the new bar better.
