Thanks Frank. dash out then, I suppose.According to MUD it's deffo dash out but I can't find a complete procedure there. Lots of depressing pictures though.
i feel better about the "gunk" now rich..K seal will work. It is extremely effective. Don't worry about it being left in the coolant system. Its only copper filings. Think of it like the platelets in your blood, circulating round ready to seal any small leak that occurs.
I think Dervis had the same issue at some stage Andy. I know he had the whole lot out when he soundproofed his 80, he might be able to advise...
Anybody else had any luck with rad weld to cure matrix problem?
Tried the K Seal route yesterday and today, I thought it had worked but another run this morning proved otherwise. TBF I will put the Cruiser in the garage and remove at my leisure. I will go down the re cored route as it saves taking 2 out and the cost will be far less than a replacement.
Is it defo necessary to disconnect the air con gas pipes? Is it not possible to undo the air con box from the heater box and move the heater box sideways and out?
Wise words indeed.Take your time, lots of photos on the way, label stuff you might forget, and such like. Keep fixing screws bundled and location marked for replacement... you’ll get there.
Christ Andy, Thats some Task mate!... Hats off to 'ya'..I was having a Spat of Tourette's Putting a double din CD player in the 80 the other day. There's a build thread right there mate...
Having fun Andy?Another session coming up soon. Should get the matrix out next go but I'll have to allow 4 hours at it.
You found that screw under the vent on the passenger side then?![]()
