- Mar 1, 2010
Evenin' All.
As many of you will know, I use my 1998 KZJ95 UK-spec Colorado for towing a double horse trailer. When I bought it, I expected the 3.0 litre 1KZ-TE turbo diesel to be well up to the job of pulling around two tons with four or five occupants plus equipment.
The reality has been different and I have suffered constant coolant loss when towing – when the reservoir overflows – and also suffered a cracked cylinder head in 2010. I should say that I don’t hammer the car at all and always try to keep it spinning on as light a throttle as possible when towing.
When I replaced the cylinder head (with a ‘Roughtrax’ unit), I hoped all would be well, but the coolant loss persisted when towing. When running without a trailer it seemed fine, usually.
A couple of weeks back my wife and I were going to collect horse bedding and feed using the empty horse trailer. Travelling along the M9 at normal legal speeds (for trailers) everything was fine and I turned the cabin heater off.
A couple of miles further on I suddenly realised that the temp gauge was ‘off the scale’ so pulled off the motorway and parked-up.
The engine bay was soaked in red coolant and the reservoir was bubbling like a kettle. I turned the motor off and let it cool for 10 mins or so before cautiously removing the radiator cap (heavy gloves and a towel were deployed and a lot more bubbling ensued). I put about 4 litres of red coolant in, started it up and continued, using back roads. All was well (though I did have the cabin heater on this time).
When I eventually got home with the empty trailer, having made the delivery to the Livery Yard, I checked under the bonnet. The top of the radiator was too hot to touch, but the bottom radiator hose was cold.
Two possibilities came to mind:
1. The thermostat I acquired from Milners in 2010 wasn’t working (though I did check it before fitting it).
2. The head gasket was letting combustion pressure into the water channels which was then ejecting the coolant. I discounted a cracked head as there was no sign of steam when re-starting from hot.
So, as the Queen of Hearts would say. . “Off with its head”.
This thread covers my findings when I looked inside and also reports on my investigation into how the 1KZ-TE is designed to be cooled. I have a few misgivings about the design which may shed light on the recurring cracked cylinder head enigma that these motors suffer.
Discussion, as always, will be welcomed.
The cylinder head was removed and cleaned-up. It looked fine and I don’t think there is a problem with it. Its only done about 2,500 miles since it was fitted last June.
The first thing I noticed was that one of the ‘blanking panels’ in the head gasket had been inflated. They should all be flat and the old gasket I took out when the head was replaced hadn’t suffered in this way.
This was a pattern ‘three hole’ gasket from Milners – it consists of three thin metal gaskets riveted together. It appears that combustion pressure was getting in between the top and centre sheets as the bottom panel was still flat. This is the front nearside panel, just below the top radiator hose outlet:
Other panels in the gasket were normal.
Looking closely at the face of the block, the gasket and the cylinder head didn’t show any obvious ‘blow-by’, though I have my suspicions about the rear nearside water channel as the block was a bit discoloured and No. 4 cylinder had a sort of ‘rusty’ look to it (it was like that when the head cracked, but I thought it would have been all shiny again by now).
So, maybe I was getting combustion pressure from No. 4 into the coolant and maybe not.
When I fitted the new head I didn’t use any gasket sealant on the head gasket. This time I used a genuine Toyota gasket and put a thin layer of non-setting sealant on both sides of the gasket.
I was very careful not to get any sealant near the camshaft oil feed drillings as I wouldn’t want that blocked.
Time will tell if this was a better approach.
So, I may have had a leaky head gasket, I don’t know for sure, but what about the way the motor is designed? Is there anything I can do to improve the cooling when towing??
There are a couple of unusual features with this engine the main one being that this is the only engine I have seen where the thermostat is on the cold water return-side from the radiator. There are undoubtedly others, but I don’t really understand how they are supposed to work.
I’ll explain.
You may be forgiven for thinking that there is a thermostat in here – in the ‘usual place’.
But there isn’t, its down here, just behind the alternator.
As we know, a number of the water channels that connect the head to the block are blanked-off by the head gasket – they can be seen here – four on the nearside & one on the offside:
(Note to all you people who drive on the wrong side of the road . . . British Standard Nearside is the left of the motor, viewed from behind from the driving position).
Also, the water pump has no external hoses – it doesn’t take its water directly from the radiator:
Instead, the water circulates around the block, past the thermostat – where it is joined by the coolant being returned from the Turbo and the cabin heater and past the large drain hole from the cylinder head.
Then around to the front, where the gallery emerges at the centre of the water pump.
The pump then sends it around to the nearside, below the cylinder head and below the channels blanked-off by the head gasket.
Now we see why the water galleries feeding the head are blanked-off, the water (presumably from the coolest part of the engine) now flows between the block and the oil filter housing where it cools (or warms-up) the oil cooler.
Above the oil cooler are three 5mm holes linking the block and the head, they won’t affect the water circulation much and, I suspect, are primarily there to prevent air locks building up in the block.
On my engine, the holes in the block were a bit rusted-up so I cleaned them out with a 5mm drill bit. The head gasket also had 5mm holes but the head only had 4mm – I drilled these out to 5mm to line everything up and to reduce the risk of blockage. I don’t think the additional 1mm (x 3) will affect the coolant flow.
The coolant now runs to the nearside rear of the block where it meets the first of the galleries connecting the block and the head. As the bulk of the flow continues around the back of the motor it meets more open galleries – allowing water to rise into the head.
At the front off-side of the head is a large drain hole that lets the coolant drop down to the suction side of the water pump. I am assuming at this stage that the thermostat is closed and there is therefore no flow into the radiator, apart from some thermo-syphon exchange that causes the top of the radiator to get hot.
It seems a bit strange to me to deliver the water from the head – probably the hottest part of the motor – downstream of the thermostat.
I have marked-up a picture of the block to illustrate my perception of the coolant flow:
As well as the flow up into the head, there is a flow forward on the off side below the head.
Hot water from the head is also routed to the cabin heater, returning to the block upstream of the thermostat. This flow is presumably cooler than the water in the head, so will keep the thermostat cool. I guess this is to maximise the heat transferred to the cabin.
I’m not sure about the turbo charger. There is one feed from the bottom of the block (coolest water) and another just forward of the thermostat. I’m assuming that it’s a thermo-syphon system with the heated water rising up to the upper hose, unless someone can tell me that there’s an impeller in there between the hot and cold sides of the turbo.
So far so good. With the thermostat closed we have a water circulation around the block and the head, with the hottest part being up top, in the alloy head.
And this is where I have a problem . . . .
Normal thermostats that live near the top radiator hose typically open at around 88 degrees Centigrade. One would expect that one living on the return side would have a lower opening temperature – and it does, the standard ‘stat for this motor opens at 82 deg C:
However, I carried out an experiment.
I heated the standard stat up in a pan of water and it gradually opened. I ran the hot tap in the kitchen until I couldn’t put my hand in it, then transferred the open stat to the hot tap water – It shut fast in under 3 seconds.
I then put the stat back into the almost boiling pan and it took a long time to open. I repeated the swap and it shut very quickly.
Now, the ‘stat lives in the block with the business end on the inside of the motor. As the motor heats up it will presumably get to the point where it opens and is immediately flooded with cold water from the bottom of the radiator. It seems it will then close very quickly.
Repeat the process – long(ish) time to open followed by a quick shut-off.
I think its very unlikely that the bottom of the radiator will ever get to the temperature where the thermostat stays open (unless you’re stuck in traffic in the Sahara), meaning that the motor is being fed small gulps of cool water.
That is probably OK if the car is running light – but towing a couple of horses over the Pentland Hills??? No wonder the motor gets hot and objects. Its working hard but there is sufficient airflow to keep the radiator cool, so the thermostat stays predominantly shut.
I can see why the motor may get so hot in places that the head is strained – and cracks.
Or does the ‘stat reach a steady state where it balances the heat in the block with the cool water from the radiator ? I don’t know, but I’ll bet it doesn’t open fully very often.
This is not a problem where the ‘stat is at the top of the motor as, when it opens, it is bathed in hot water and so stays open until the whole motor cools down to below its opening temp.
I looked on various websites and all quote the standard ‘stat for this motor as being 82 deg. However, Land Rover Defenders have 88 deg stats, with 74 deg versions as an option.
The Max Ellery manual for the 1KZ-TE states that the standard ‘stat is 74 degrees!
I enquired of Toyota and a 76 deg ‘stat is available – so I’ve fitted one:
Whether this will make a difference remains to be seen but my gut feeling is that it won’t. I took the truck for a run (without a trailer) and when I got home the top of the radiator was hot, but the bottom hose was stone cold.
I know that to achieve thermal efficiency the combustion chamber has to be as hot as possible, but unless I’m missing something obvious this design is flawed. My temperature gauge doesn’t normally move from the normal mark – even when its chucking the coolant out. It only reads high when its lost most of the coolant from the head and top of the block and by then it could be too late.
Oh yes, the radiator and cap were new last June. I flushed it out with a hose and it is clean inside.
So, the next step if I still lose coolant when towing ?? – modify the top coolant outlet to take a thermostat and remove the lower one (not that simple as there has to be a steel ring with a rubber gasket around it to make the thermostat cover seal. I’ll just cut the centre out of an old ‘stat and put the outer part back in).
There isn’t a great deal of space for a conventional thermostat where the coolant exits the head so I might have to be innovative with some alloy welding. I used to have a BMW K1200 motorcycle that had a cylindrical thermostat that passed enough fluid to cool a 130 BHP motor with two small radiators (and fry my knees in traffic). Maybe one of those could be adapted to fit.
Food for thought.
OK folks, over to you, tell me where my theories are flawed and what I have been doing wrong.
But remember . . . 1,000,000 cracked heads don’t lie
Bob.
I’ll explain.
Food for thought.
Bob.
