Beau
- Jan 28, 2011
Best 3 core i can find is for a Surf Beau http://www.ebay.co.uk/itm/56MM-CORE...544?pt=LH_DefaultDomain_3&hash=item3f4dff0a18
Dimensions are 600mm x 645mm x 65mm compared to an aftermarket 90 series 2 core rad found on ebay Oz which offers 720mm x 680mm x 60mm , so height and width are smaller with only 5mm depth difference so yeah it should be easy enough to fitwhat are them small lugs with the blue caps on at the bottom will i have to cap them ?
I'm not sure its worth the extra price and messing about even if it does offer some small benefit over a factory rad especially as its an open question as to whether or not it will show an improvement at all .
The surf rad's are smaller than the cruiser one's so I don't think it's worth messing around with them! If it was a direct fit, it would be tempting! The plugs at the bottom is for the automatic box cooler, which you won't need. With the manual rad, you'll in theory have more cooling surface area and water capacity so I wouldn't use the auto rad on a manual. Like you said, it's probably not worth the hassle unless you can find a direct replacement 3 core for a reasonable price.
Regarding the rad and AC difference, I too have read that the gap should be as close as possible. Some cars have a shroud in between these two so that the airflow doesn't escape in between the gap! I worked on a Volvo XC90 and the AC and Rad are sandwiched. Having the AC on will increase temps in two ways. The AC clutch kicking in will draw some power from the engine, and the AC rad heats up the air before the same air cools off the main rad.
