hillbillysimon
- May 19, 2011
1995 80 series manual diesel
All ignition lights remain lit with engine running, although the only thing thats at fault is the alternator not charging the batteries, oil pessure is ok, as is the coolant level & brake fluid. Very occasionly the lights will go out, but as soon as the engine is shut off & then restarted they're back on again. The lights do flicker from bright to dim when the indictor switch is used, maybe pointing to a bad earth.
Has anyone else come accross this problem or got the faintest clue where to start looking ???????????
