Trevor
- Jul 25, 2010
Finished swapping over final bits from the old engine to the Surf one. Then put in the temp alarm.
Dropped the sensor in the top hose but it was letting a small amount of water through, put some RTV inside and the outer edge and everything is water tight now.
I stripped and tested the viscous fan and finally all is back in the engine bay.
Brakes next as one disc trashed after the pad went to metal, pistons seized in the front calipers so 4 discs and 4 calipers fitted today.
Engine is showing low oil pressure, will change the oil filter then sensor just in case. However I suspect the oil pickup pipe in the sump may have a pinprick hole or 2 in the weld and might be acting like a hole in a drinking straw so the oil pump can't lift enough oil to the top end.
Passenger handbrake is full of diff oil, the Swiss mechanic had all sorts of problems with it and suggested it may have a bend in it so I'm now looking for another halfshaft ideally with wheel bearing and ABS ring already in place....if you have one please PM me.
So Fiery is still resisting a bit but I can see the light at the end of the tunnel now, worst part is going to be disappointing Sis as I thought it would all be finished for this weekend.
