Trevor
- Jul 25, 2010
In order to get the sump off Lil' Blue I decided to attack from below rather than lifting the engine up. I've got as far as splitting the bottom ball joints, popping the driveshafts out of the front axle and dropped the front propshaft.
I've undone the axle bolts on the side of the carriers but have been thwarted by the 12mm allen socket bolt on the underside of the crossmember, it turns fine but the rubber bush above just keeps turning and I can't figure out how to remove the damn thing, there is no nut I can see at the top.
Anyone got any hints or tips for successful removal?
