SteveS
- Jan 12, 2013
Have completed the additional 'kitchen' lighting. The 12V was taken from the dome rear light (as this switches on door opening etc and the 0V is switched by the tailgate open switch in the upper tailgate. I ran a small diameter twin mains wire from the dome light rear above the roof lining to the rubber umbilical that links the upper tailgate. I pushed the wire along the roof lining using a long steel rule, working from the rear (with Christmas trees holding the rook lining in place removed to allow the rule to be shoved in. With the wire in position there I then threaded a steel wire (in this case my CB aerial) through the rubber umbilical, taped the other end of the cable to it and pulled back and out: the cable now threaded through the umbilical. Next step was to thread the cable down the LHS tailgate channel. For this I used an electricians tape with the cable taped to the steel. Once pushed through then the cable was temporarily fitted to the existing loom that runs across the bottom of the upper tailgate so that lengths and routing could be sorted. I left 'tails' in the cable routing so that I could attach the plastic surround holding the LED lights via spade terminals.
Once all the wiring was in approximate location and the tails terminated the cabling was commissioned. Continuity checks completed. The 12V coming from the dome light attached to a metal strip in the light moulding carrying unswitched 12V (from the vehicle master interior light controller. This has to be done as the wiring to the switch is of a flexible circuit type rather then traditional cabling. The connection to the dome light 12V was made by wrapping the wire around the metal strip (a bit like a wire-wrap post) and then fixing with a miniature tie wrap and some super glue. At the other end the 0V was connected to the switched side of the tailgate open switch (so there was now a live circuit. Voltage checks completed and then the LEDs connected. All working!!
