Help please with harsh knock / rattle 100 series
Mikeharris1992
Someone please help
my 100 series has a really harsh rattle / knock from the front. Can feel it though the floor / pedals !
but then at random it won’t do it at all for a whole journey
Above 25mph, you hit a bump and the rattle start. Doesn’t change the faster you go, hit another bump it may stop or just for a millisecond then start up again.
I would describe it like the wheel / tyre rubbing on something, but there not
It’s had new anti roll bar drop links, there is no play in the roll bar mounts.
There is no play the wheel bearings.
very Slight inner rack joint play
very slight lift in b bottom ball joints
front diff bushes have very slight movement
please any help would be great or advice
Mike
SteveJB
Dry joints in the prop shafts try greasing up all movable parts a cheap fix if it works and check for excessive play check for movement on front diff mount and drive shafts if you have a split in front shaft boots the grease can escape and have dry cvs easy fix again few quids for boots if other members know anything else they will let you know
Mikeharris1992
Yeh I’ve tried all that too
Took the prop off checked the joints and the slider all ok
Slight play in diff bushes but this noise is only harsh some of the time
rmurphy5
Hi Mike, what mileage has the vehicle got? What are the shock /ahc ram mounts like?
Mikeharris1992
325,000 miles !
It’s got peddars ahc delete suspension
Il check the shock mounts tomrrow, it’s like so thing is loose, but then it goes silent.
Like a rubbing noise, like a tyre rubbing something, doesn’t change pitch with speed, always the same noise, never louder or quieter !
Mikeharris1992
Found it, near side front drive shaft spindle is worn, there must be a brass bush or something that support the rear section of the cv joint.
need to try and find a replacement
Mikeharris1992
So done that, and there is still a rattle, it’s like the undertrays are loose, I took them off and the rattle is still there, it’s coming from the front in the middle, really running out of ideas !
Philip amos
Do you have catalytic converters they can work loose inside. Just a thought
Mikeharris1992
It’s literally like something is loose, I’m now wondering if it’s like a panel, or a worn body mount or something. Really really strange noise !
Philip amos
Sometimes almost impossible to find , I’m convinced my exhaust knocks sometimes but can’t find evidence is yours v8 or diesel
