John, it was lovely to meet you both. I'll thank you not to dwell on my injuries thank you. I am almost walking unaided now.
Well you are in the right place now that's for sure. Get to Lincomb or we'll terminate you membership. It's the law.
All you have to do it turn up. A Landcruiser guarantees entry. Quite a haul from Suffolk.
It's connecting the positive of one battery and the negative of the OTHER battery that's going to get you in trouble.
What I am wondering is, if the DS battery is OK and the Pass battery duff, when you connect to the DS battery to jump it, just how effective is that? Genuine question. All you are doing is putting MORE 12v into the good battery. You aren't generating 24v are you. Will it start? I would be tempted to jump some feed into the Pass battery just as if I were mimicking the alternator, then disconnect and turn the key.
No?
I agree with all of the above. The thing is to disconnect the batteries as Chris has said and charge them individually. Or bridging out the duff battery with a good one is also a good plan. However with two duff batteries still connected, jumper cable to the DS battery and leaving the donor vehicle connected to pump charge into the pair will then give enough generally to start if left long enough. It all depends on the state of the batteries and if any faults exist as to what will work best.
I think we are all on the same page here.
Welcome John! Pics as soon as you can please![]()
Welcome, looking forward to the pics.
Well..!!! It's taken a while, but kitted out inside now; Rear Bulkhead & Racked, Dual Leisure Charging, Inverter etc.. Minus 40 Fridge/Freezer. Outside; King Springs, Koni Raid Shocks, 35" BFG ATs on Steels. Lots & Lots still to do.... Not done the bumpers or under body protection yet, along with many other plans!!! But I'm getting there...... slowly.!!View attachment 105341
