mr_magicfingers
- Jun 7, 2013
Yesterday I spend a bit of time looking around the front of the truck to see if I could figure out where to mount a bracket for a light bar. As the bumper is all plastic, that's out as I don't want it bouncing around. There's not many places to bolt something onto easily.
I was looking down and saw the two main bumper mounts have two holes in. Any reason not to run a couple of bolts through them? My idea was to get some 25mmx3mm steel bar and weld up a shape that could be bolted onto the bumper mount then fit through the front grill and make a flat surface for the light bar to bolt to. One each side of the number plate.
Just thought I'd check to see if it sounds reasonable.
