lc27
- Sep 30, 2012
Hi gents
Well the starter issue went away as a reconditioned started was fitted. Oil filter was also replaced
Since then, the oil light comes up after few minutes the engine is started.
Does the oil light measure pressure or level of oil?
Pressure seems to be as usual, so not sure if the sensor was damage while replacing the starter? Or if it a genuine fault
Oil level is on the full mark
Any hints? Also where does that sensor goes? Any body experiencing the same issue.
M
M
