hi guys
Considering getting a 90 and I have seen a petrol 1997 vx colorado. I like it, but been told by a garage guy that it does 10 miles per gallon.
That cant been right....help.....
what are the owners experiences, are you getting 10mile or is it actually 20 as listed on spec lists.
please help as thinking if getting it as I have already seen it, but seeing it again this sunday, since the guy did not have his paperwork folder with him (meant to be fsh).
i should add, it will be for family use. motorways and travelling on A/b class roads in the welsh valley which will be mostly duals.
sadly no mud or pulling anything.
worse case fully loaded trips to scotland (homeland) from wales.
really want to check if i can get into the 20s then maybe worth getting over a td.
with cruise control working, i dont expect to drive it above 65-70.
do they last as long as a td?
wanted some thoughts here first before i take the plunge
cheers up front and keep up the good work
TD are overpriced for my little budget just under 3k!
