Leaking Diesel Pump
Ben Stratford
When the engine is running the left hand 2 pipes are leaking diesel at the junction with the block.
What to do about it?
Are there seals in there that can be changed?
Thats grest, thanks Firewout. So a rubber o ring and a copper gasket in each delivery valve. Looks like i will need a multipoint socket too to undo them with like 60 points or is there a special tool?
Thanks for your help
I think looking at your pic that they will undo with the larger hexagon once the locking plates are removed, and the fine teeth around the outside are purely for the locking plates to hold them by.
Make sure they are scrupulously clean around before you start to remove anything, protect any open ends with caps orvclean plastic and rubber bands and submerge any small parts in a pot of diesel. It is imperative that not one grain of dirt gets in as gaps are so small a piece of grit or dirt will cause havoc if it gets in.
Will give it all athorough clean first and blow dry with compressed air.
Been looking up on u tube and it cant be cleaned too many times by the sound of it.
So will heed your advice and abort if windy
Yes, I have that on my home computer thanks Firewout. Must save it at work too!
Will see if cruiserworld has the seals and gaskets
