Will it be On the road soon too then ?
Don’t rush him Andy, this will need at least a one-week drum-roll
Brilliant work Ben, as usual
Brilliant work Ben, as usual![]()
awesome job! I love how the truck is looking, well done!
Good work on that bumper Ben looking good !View attachment 151716
I cut and folded some more 3mm sheet.
Tacked them on.
Welded some more 3mm sheet on to the bottom of the wings to add some strength and to stop me getting hung up on things.
I also added some 50mm x 10mm steel to brace the whole thing further forwards on the chassis
1 last trial fit.
Took it back to work, fully welded it all up then smoothed all the welds down, welded the recovery points on and drilled some holes for the LED lights and a hole for the exhaust.
Got it electroplated.
Also got the mud flaps brackets done and the 2 chassis plates for the bumper.
Unfortunately there was a short circuit and they didnt get fully plated so had to get re-done.
I couldn’t see clearly but I’m guessing those recovery plates are inserted through a cutout in the 3mm steel to be welded to the sides of the chassis plates. Did you consider doing the corners at a 45 degree angle at all? Are they copper or bundy tube?
(Did someone once mention staying single and doing 5 years down the mines? Surely not!!)
Hey @Ben,
I've just seen on Early Land Cruiser Spare's Facebook page he has an RJ70 in for dismantling - it's a black framed window model with a FRP roof... now that you're not in sunny QLD I thought the FRP might be of interest...
