fridayman said:
wobbly said:
Fingers crossed - have you got a job lined up, seems to make a big difference.
I've applied as a sponsored (my brother is in Brisbane) skilled migrant. With my brother's sponsorship we only needed 110 points and we have 130+ anyway, so we're hoping it is a case of "when" rather than "if" we get approved. But this has nothing to do with Ben's truck... Sorry Ben
good luck.
maybe one day we can meet up for a spot of 4x4ing, outback style!
TonyP said:
Yeah back on track, have you finished the draws yet? Common slacker
getting close now mate!
so on Tuseday i picked up a piece of alloy for the small drawer front, to replace the piece i cut too small.
and got it drilled and bolted in place.
i also picked up a piece of alloy angle from wickes.
i cut the angle to length, and scribed the ends to the exact angle and shape of where the angle meets the rear pillars.
once i was happy with the fit, i brought it into the workshop to drill and countersink the holes for fixing it to the ply.
i then screwed it in place.
so that was yesterdays effort.
it was a lovely day at work today, and definitely the hottest day of the year so far. was working on a roof all day in the sunshine.
couldnt believe when i got home the UK was hotter than Melbourne!
granted it was 4am there, but this is the first time this year weve been hotter than there!
anyway..........................back to the drawers!
decided i wanted to get the latches fitted.
so i found some 10mm x 10mm solid bar in the shed.
cut 2 pieces to length and drilled some holes in it.
found some suitable stainless steel countersunk headed bolts.
i unscrewed the alloy angle trim from the edge of the ply, and then positioned a piece of the 10mm steel bar in place, and drilled through the holes.
got a countersink bit, to countersink the ply to accept the bolt head.
and bolted the steel in place, making sure i used plenty of threadlock on the bolts.
got the other one done.
cut the excess thread off the bolts.
marked where the latch needed to go, and brought the drawer into the workshop.
drilled a hole, cut the area out with a jigsaw, and then finally cleaned the edges up with a file.
perfect fit!
this bolt on the back is where the adjustment is for how tight the drawer is pulled into the frame.
refitted the drawer, and adjusted the bolt until it closes nice and tight with no rattle!
cut a piece of ply to act as the stop.
sprayed some silicon grease on the runners and bearings.
little drawer done!
decided to put some stuff away in it.
so the little drawer is for all the recovery gear that i need most often. the idea being that when im stuck in a huge hole, about to winch up a muddy incline, etc. all i need to do is open the small back door, slide the small drawer out and get what i need.
so...............................dont use the home made, hardwood, high lift jack base very often, so that went in first.
followed by jump leads.
followed by high lift jack adaptor, which fits into my rock sliders and front bumper.
followed by compressor.
quick strop, 8meter strop and a few D shackles next.
followed by my kinetic rope.
marked where i wanted the latches on the big drawer and brought it into the workshop.
drilled a hole in each marked area, ready to be jig-sawed out.
latches fitted and drawer back in place.
decided to stick some stuff in this drawer.
so in went saw, spade, machete, bolt croppers, and crowbar.
socket set, and scissor jack.
full size C02 fire extinguisher, and a few other bits and pieces.
wheel brace and 2 hatchets.
also found my snatch block for the recovery drawer.
very pleased with the latches. there a nice solid heavy duty cast alloy type lock. i like the fact they can all be locked, or can be left in the unlocked position, where by they can still be used as latches.
i also like how they all use the same key!
hoping to get them finished tomorrow, but my latest copy of 4wd action has finally arrived from OZ, so going to be busy reading that for a while.
such a shame none of the uk 4x4 magazines even come close to the quality of 4wd action. i certainly wont be buying total off road magazine ever again!
