- Feb 2, 2013
Reverse gear on my trucks seems to be out of sync , when the trucks cold selecting reverse is not usually a problem but i have noticed after only a short run it doesn't want to go in and i've sorta subconciously learnt to slip the clutch a little to make it catch . Today after 60 mile round trip the problem seemed much worse . 4 attempts at a stop failed to make it engage , but given i where i was (blocking entry and exit to a trading estate) i lost patience , gave it a welly full of rev slipped the clutch and rammed it into gear causing that grinding noise we all recognize as someone abusing a gearbox . 10 minutes later i arrived home and messed about a bit going back and forth where i do my usual 3 point turn and everything seemed fine ?
