I've been on with a bit more and it's been a busy few days.
had to repair the front bumper after it got damaged in a carpark
The metal part got pushed in and bent, it hit the piece on the end of the chassis so bent around it! the front left plastic part was scraped and low! My young 'un nearly learnt some new words
Bashed back somewhere near it's shape and some filler applied
All rubbed down and primed (makeshift panel stand of some concrete blocks)
All painted and looking better, it's not perfect but i'm happy with the outcome
Got the winch wired up and finished off, mounted ready for the bumper
Can see the winch nicely through the top and get to the freespool lever
Made a cover for everyday use, I welded a captive nut into the bumper either side and a couple of stainless bolts hold it in place
Just need to put the plasma on as thought i'd give it a wash first.
Ran the wires just under the grille and upto the engine bay
Solenoid mounted next to the battery on a bracket screwed to the front panel
I couldn't decide where to fit the wander lead plug but the A bar has some spare brackets on the sides so a couple of holes drilled and mounted it in
Wires run into the bumper then upto the engine bay with the other cables.
To make it easier when the bumper has to come off in the future I've put some terminals on which sit behind the grille so easy to get to when needed
Made a loom up to extend the wiring which has been finished off with loom tape
Then most importantly I bolted the 35's on
It drives nice still and performance isn't really lacking, the auto box doesn't seem to be upset either, just need to check the speedo for accuracy! Forgot how noisy mt's can be though lol
Sat just outside the mancave where I've spent a few hours recently
