chadr
As thread title suggests, my battery has been behaving very strangely over the past week or so....... the battery is a E44 Varta "Silver Dynamic " 77Ah, bought and fitted in June 2018 from Tanya Batteries and has never given any issues previously. The 90 hasn't been used as much as before due to lockdown etc. but it has still been out and about at least once a week for journeys of around 30-40 mins /15-20 miles or more and always started on the first turn of the key.
About a week ago, I tried to start the 90 and the battery was so flat that the ignition tell-tale lights would barely illuminate. The starter didn't even "click" or make a sound. So out comes the trusty CTEK MXS 5.0 charger and connected it up in-situ, putting the charger on the "car" +"recon" mode and left it overnight. When I checked in the next morning the CTEK's red "error" light was on and it was showing that it had only got to stage 3 (Bulk charge - 80%).
It was very windy that day, enough to sway the car, I thought that a connection may have come loose and caused the short/error - I've been using the CTEK on our cars (and neighbour's) for a few years and I've never seen that error before . So I removed the battery from the car, brought it indoors, plugged the charger in and left it overnight, again.
In the morning the error light had come on and it had got to the same stage 3 - so exactly the same as before. At this point, though I thought that the battery was dead beyond recovery, I fitted it back in the car - thinking that if I needed to move the 90, I could always jumpstart. In the meantime I did some googling /YT, which suggested it might be worth checking the alternator. So armed with a digital multimeter (good ol' Amazon 1-day delivery) I did the following tests with readings;
Checked the battery before any draw : 6.9-7/0V (which seems to suggest it's dead!)
Jump-started the car and at initial (raised) idle : 14.2-14.4V
Raised engine rpm to 2500 : 14.2-14.4V
Put some load on alternator (lights, radio, fan etc) : 13.8-14.0V
Back to idle and no load : 14.0-14.2V
I left the engine running at around 1500 rpm for 5-10mins and the reading was pretty steady at around 14.2V
Switched off the engine and checked the battery, now reading 12.9V
I switched on the headlights for 20 secs and the reading dropped to 12.7V
Tried to start the car and it fired up instantly, I left engine on 1500rpm for a few mins and switched off, still reading 12.7V
So I come back to the car in 2 hrs and tried to start it - now back to day 1 - i.e. not even enough juice to light up the ignition tell-tales and not even a "click" from the starter. Battery voltage reading is now 8.9/9.0V. WTF!
Hopefully the above suggests that my alternator is OK and it is a genuinely duff battery - Varta provide a 5 year guarantee, so I emailed Tanya Batteries with this info a few days ago but have not received a response yet.
Sorry for the rambling post
