This arrived today. Luush!
http://www.outdoorworld.co.uk/kampa-gey ... ter-system
Now firstly don't be fooled by the picture. I researched this for a while and decided that this picture of a beige / grey one looked like a newer model. It isn't. It is a pre production shot used by Kampa. I know because I rang them. The Kampa one has always been green. However there are some other makes around.
So, out of the box - couple of clicks later it's all together. Pretty robust although I think I would use sealant on the shower threads just to help with the rough life it will get. Very light indeed. It comes with a carry bag too.
[attachment=1:3rttweaj]P1000956.JPG[/attachment:3rttweaj]
[attachment=0:3rttweaj]P1000960.JPG[/attachment:3rttweaj]
Does it work. Blimey Charlie, it certainly does. Would you like copious amounts of steaming hot water (almost) instantly with enough pressure to be able to shower properly? Then this is for you. I can't fault it. If you leave it circulating in the bowl, the water it actually too hot to put your hand in after a couple of minutes. The pick up hose will actually screw onto a water container. I have to sort that out, but in the meantime, you can just drop it into a Jerry can. A water tank will be going in very soon. The on off on the shower head controls the burner too.
[youtube:3rttweaj]Vh15devtYpU[/youtube:3rttweaj]
EDIT: That should be it, CJ (from GS )
Sorry, I just don't get how you use the You Toob feature. Which bits do you leave out between the brackets?
