Red Oktober
adrianr said:ATF and its your transmission cooler i would think.
built in to the bottom of the main radiator .. ?????
i'll get a pic
Rob said:You will need to top up the ATF when you put the rad back on
Dexron II is probably good enough if you're looking for minimum spec. Otherwise put something fancier inRed Oktober said:right .... is that any atf ...or a specific type
Dexron II is probably good enough if you're looking for minimum spec. Otherwise put something fancier in [/quote:wjb2gad3]Andrew Prince said:[quote="Red Oktober":wjb2gad3]right .... is that any atf ...or a specific type
wobbly said:Just had another look at the picture - if the stat has didintegrated in situ then the bits must still be in the block, not the rad.
I dont understand how that can have happened though, the stat wont just fall apart, I wonder if it was broken previosly and they refitted it so the seal was ok, no sign of sealant which I would expect to see if no stat in place.
Fill the Atf through the pipe where the atf dipstick is.
Pete
wobbly said:Its the orange dipstick just below and to the left of the battery when viewed from the front of the car.
Pete
wobbly said:Hi Carl
Good result then.
I test my truck on Halden Hill - right towards Newton Abbott - from where the road splits at the bottom, go up the hill, pretty much flat out you should be doing 48mph in 3rd and no sign of overheating, i dont do the a380 side as its not as steep but is a lot longer so speed tends to drop off!
Pete
