silvercruiser
- Mar 22, 2010
whoops
I feel quite vindicated - I decided to mount the motors with nylon M3 screws instead of the normal metal screws. The idea was that during a crash they would give and save the shaft. Normally, the slightest knock and the shaft bends.Ouch, have you bent the motor shafts or damaged the motor bearings as well?
I had a bit of a problem last night.
Crashed into the side of a house one road over, about 6 houses away. Motor failure
Geofence is available in the current firmware. You need to turn on auto-fence. It'll not let you fly more than 100m away from the takeoff point. I think the response is RTL if it hits the fence.
Latest firmware is very good. Mine is (apart from the pic above) rock solid. On a windless day it just sits there and hardly drifts, with gusty wind, it works hard but pretty much stays in one place. Compared to what it what when I first started flying it, they have come along leaps and bounds in stability.
Make no mistake, they'll be armed soon and they will be in battle.
Not much of a rock band either. And this is more like pop, with a slight rock tinge. And that's a factnice, not much jumping about for a rock band though
