You're not getting this I can see. Gravity is not the most powerful force in operation. That's why planes fly. Lift overcomes gravity. I've said before, the conveyor idea is a total red herring. it has nothing to do with whether the plane flies or not. The wheels are just spinning in neutral effectively.
OK last example. Fast flowing river like the Amazon. Take an airboat. Those great big skiffs with a propeller on the back that they use in the Everglades. If the river is flowing at 10 m/s and the boat fires up, it has to do at least 10 m/s to stay still, yes? Then when it revs up it moves forward. When it has enough revs on for say 20 m/s it will only be doing 10m/s forward, yes? Cool.
However, there's a major difference here. In the river, the force is acting against the hull, pushing it. With the plane, because the wheels aren't connected to anything (a bit of friction in the axle) the conveyor cannot exert a force on the plane. Nothing of any significance at least. The plane will move in relation to the airport. It doesn't matter how fast the belt goes, all the engines have to do is over come the few pounds of resistance in the wheel assemblies. Given that a man has pulled a jumbo jet for a world record, you can see that the motor off a mobility scooter would be enough to do that! So four bloomin great jet engines will be more than enough. So that's all they have to overcome to be stationary. A bit of rolling resistance on the wheels. One the plane throttles up there's no force holding it back. The wheels will be spinning like crazy but the plane will take off like normal minus the power of a shopping scooter.
