I checked my lights before the MOT today and the rear fogs don't work, the light comes on on the dash, and the bulbs seem Ok, but the fuse slot doesn't have any pins in... is there another fuse for the rear fog?
Have they ever worked ?I checked my lights before the MOT today and the rear fogs don't work, the light comes on on the dash, and the bulbs seem Ok, but the fuse slot doesn't have any pins in... is there another fuse for the rear fog?
View attachment 138912 View attachment 138913 View attachment 138914
mine is actually that fuse. don't know why..Hell, try them ALL!
Good shout Steve, I would never have found that otherwise, luckily on my truck it is wired with an intercepting loom so disconnecting that and connecting back as normal was the key!
Pulled the ECU - B fuse and it is the one for the rear fog??? But if it is pulled you have no fog light on the dash either...
Thanks all for your help!
In mine it is below the jack in the passenger rear cupboard in the boot.
Yay, now all you need is some fog and you're good to go
Do you have the fog light symbol on the dash when the fog light is switched on?
