- Mar 1, 2010
Thanks Chris. That's 12lbs on the wheel stud pull?
I'll check both readings as well.
Frank
Frank
Frank, have you read the first couple of posts on this thread? There are links to a detailed write-up on how to set the pre-load, as Chris is describing herefrank rabbets said:Thanks Chris. That's 12lbs on the wheel stud pull?
Frank
frank rabbets said:It all came to light with me when I jacked up the front axle and turned the steering. It was biased towards the centre. When I turned each hub independantly without the tierod on they were almost stuck in the dead ahead position. On stripping there were big grooves in the outer races but still preload. I chickened out of 12lbs as it stretched the hub by about .030" so I went for 6lbs. No probs so far.
Frank
frank rabbets said:Hi
I cannot rember the exact measurement but the theory is the same.
When I assembled the hub and did the top screws up untill there was no play in the trunnion bearings there was a gap of .030" above the shims. When I fully tightened the bolts untill the gap went the preload was correct but I was not happy with this much stretching of the hub, even though correct by Toyota statement. Just me. Any preload on the bearings must meen that the hub is being stretched.
Frank
