steven.miles3
- Oct 28, 2013
Hi
perhaps they knew they had a bad batch of pressings around the time my LC was produce.
Mine is 7/2004 production, and has the shift lock....I have found out the definitive answer. Shift lock was not fitted to the Land Cruiser Amazon 100 between 08/2002-07/2004, this is when they first introduced the 'G' shaped shift gate, (as opposed to the straight up and down), because Toyota in their wisdom thought that the shift leaver was not as easy to move by mistake, then they started to fit Shift Lock again for the 05 MY and on, for some reason.
So that's the answer.
Just went to my Toyota dealer they took pictures sent them to Toyota GB, and rest is history, the rust spot upper was just above the long 'Land Cruiser' about where the 'N' is, and the lower were around the two threaded holes for fixing the number plate. They would have been so easy to repair, but Toyota insisted on new parts, perhaps they knew they had a bad batch of pressings around the time my LC was produced.
