BobMurphy
- Mar 1, 2010
Folks,
Its time I checked my tappets as I think my 1KZ-TE with the recent Roughtrax head is a bit down on compression (it spins fast on the starter and doesn't start well - hot or cold).
I have looked on e-Bay for the special tool that compresses the bucket followers and there are loads of them (all made in USA). They all look like curvy pliers.
Problem: Some say "Not suitable for 3.0 litre diesels up to 1997". Now I'm not aware of any differences in the 1KZ-TE motor between 1997 and my 1998 one.
Has anyone got a bucket follower compressor (with the separate jamming device) and if so where did you get it and does it cover all years of 1KZ-TE ??
Thoughts would be appreciated.
Second Question: Is there a bucket full of assorted shims anywhere that I could have access to (I'll obviously pay for what I use)??
There are 18 different thicknesses and 8 valves and the shims are around £6.00 each .
I'm going to have to measure the valve clearances, remove the shims and see what I've got, then order the new shims of the appropriate thickness - which is a bit of a long-winded exercise.
Life used to be so simple when all I needed was a couple of spanners and a set of feeler gauges .
Bob.
Bob.
