Hi all,timing belt light come on today and just wanted to check I'm looking at the right one for my 95 lwb 3ltr td from roughtrax code is CAMKIT02 thanks in advance for any help
I would guess yours is a KZJ95 Auto 3.0L 1KZ-TE, plate under the bonnet just in front of the steering wheel will give you this . Roughtrax allows you to select and save your vehicle and if you do and then when stumble upon a part that may interest you via google images or a web search which happens to be sold by roughtrax the description will be marked with "this part may not fit your vehicle"
