Hi all,
I really appreciate all the great info and advice everyone's giving. Thanks very much.
I had a 1hz in an 80 series a few years back. It was my first big cruiser coming from a 70 series and it was an auto too. I towed regularly with it 16 ft ifor Williams with a vehicle on it and I've got to say it didn't seem too bad. Low end was very torqey and just used to let it do it's own thing. Thrashing it never increased speed really. Was much better imo than landrover 200tdi I'd used previously. I did crack the head but I did do a couple hundred mile round trip with no water in it. Rear heater hose snapped in half. Sounds unlikely but 100% true. Only realized when I got home as it smelt very hot and was pinking. Filled it up when cool and it drove ok albeit pressurized and steaming from exhaust. When I got my next 80 with turbo obviously I realized how much more poke it had. I can't really knock my 1hz to be fair. In fact I have another cruiser project lined up with that very engine. I think we're all just used to the power we have available and naturally turn nose to anything with less.
It's interesting to hear a comparison with the 200Tdi. As I mentioned, I had a 300Tdi, which was basically the same in terms of power, and coming from the petrol Volvo that I had before it, it seemed like it was unstoppable, but I'm sure if I went back to it now, it would seem a bit lacklustre - but I still prefer the Tdi to the Puma that I have now for other reasons, and it wouldn't bother me if I had to go back to it!! So I do think it really depends on what you're used to. As I say, I don't tow for a living, and I'm not remotely bothered about speed etc in a vehicle like this, providing it can keep going (on tarmac roads) without needing low range or anything silly, so from your experience it sounds very much like I imagined it would probably be - slow but workable. Regarding cracking the head, it's pretty impressive that it kept running that long with no water in it to be honest!! And good luck with your project!
ok, my last post on this as im starting to bore myself, let alone anyone else..
by diesel 80 series i mean 1HD T or 1HD FT.
diesel 80 series.
diesel 80 series.
diesel 80 series.
every single part for the 1HD T engine is still available new from toyota. bar the fuel return rail. you can still buy new a short block and complete cylinder head.
it ticks every box other than: being a new vehicle and cubic load capacity of a LWB 70.
Haha, no worries! I see where you're coming from, and I very much admire the 80 series, and I can't see why Toyota don't still produce it in some remote part of the world as there seems to still be so much demand for it, but I just can't justify buying a vehicle that old, as I'm not really looking for a project at the moment! And it's true that I could do with the extra room in the 78.
if you keep everything in tip top order, it shouldnt be a problem. push things and it will quickly become one.
I would plan to keep everything tip top, as I'd be keeping the vehicle long-term, and it wouldn't be towing very much at all. Probably an average of 800 miles a year on motorways.
Vehicle towing ratings here in the UK are calculated using vehicle weight rather than power so a 1HZ engined LC may well have the same rating as the same model fitted with a much more powerful turbo 1HD-T/FT.
The 1HZ is slow but practically bullet proof, many have succesfully had turbo's fitted retrospectively, so I doubt you would actualy "over stress" it. It just wouldn't pull a heavy load very well go very fast.
Ah right, I thought it was something like that.
And I think you're right - I think it probably doesn't have the power to overstress itself too much, being that it's quite a big engine by today's standards, but with much lower power output than newer engines half its size, which must be part of the reason for its reliability.
Different strokes for different folks , I'd rather have an old defender than a 120 and I'd rather drive a 90 series cruiser over both .
Just test drive what floats your boat and get a feel for it . For a benchmark to start it would be worth taking an 80 for a spin . For me the added value of age is they are exempt from much of the nanny state rules .
Yes, I'm of the same mind really. I know I have a 120, which I'm now selling, but I'm of the opinion that the real 4x4 workhorses just aren't really produced anymore, save for things like the 70 series. All the modern ones are great on paper, and they're technically excellent off road, but would you really take one of the modern Land Rover "Defenders" or even the new LC 250 to a remote area with no modern facilities - you're relying on 100 ECUs and fibre optic networks, all of which are sensitive to water and dust, and when something does go wrong (which is pretty likely with all that complexity, plastic engine components, emissions treatment etc), it will likely be impossible to repair.
That's what I plan to do. I'm in no hurry to buy and I'm just exploring my options really. I'm going to take a 1HZ for a spin at some point so that'll be interesting. And I know what you mean about all the rules - drives me mad!
@DerekV maybe I didn't word it well, but the 1hz is a nice place to be in without a doubt. I drive one everyday more or less. But buying a new one in 2025 is where things go a bit nutty.
And again, make sure you drive one before you buy one!
Haha, no your wording was fine!! I think we just all have different criteria for what we're looking for. Personally, I'm not looking for a powerhouse - I'm after near absolute reliability with the ability to do a little towing occasionally without major issues. When it comes to 4x4s, I'm very much of the old school - as basic as possible - if I'd had the choice between the Tdi with the mechanical pump or the modern Puma engine when I bought my Defender, I'd have had the Tdi every time!!
