Olazz
- Apr 23, 2010
Guys, I have a 12v water pump that draws a Max of 3.5 amps.
It has no switch and I want to wire it to an auxiliary battery.
The question is, do I need to run it via a relay and switch or can I run it straight off a switched ciggy lighter plug?
If I do run it off a switch and a relay(direct to battery) any idea of the fuse rating I need?
Help greatly appreciated.
