- Feb 24, 2010
I found the details for the injector seals recall. You should be getting an email / letter / phone call from them if you are affected but just in case, you can check yourself.
Model Vin Range Manufacture date
KDJ125 JTE AZ29J# 00019035-00050831 June,2004 Through October,2007
KDJ120 JTE BZ29J# 00049705-00160767 June,2004 Through October,2007
Oddly, mine (a 53 plate, Jan 2004) is not on the list which goes against the "it was the early ones which had the problem" consensus. Will see if I can find out what the change in June '04 was.
