- Mar 1, 2010
Hi
Got into LC and turned ignition on. Battery voltage was normal. Started engine OK but then all lights on dash came on and voltage dropped to circa 2 volts. Then after a few seconds everything OK with instant full voltage. If the alternator has a fault is it possible for the voltmeter to drop with both batteries fully charged? Done a search but can't find the specific answer.
Frank
Frank
