11.5v is quite low really meaning they're quite discharged from what you'd expect, had it been standing for a month or two since it was last given a good run or charge? 45 mA is quite high, I would expect it to be much lower on an 80. It could be a faulty alarm, ECU etc but it could also be the mismatch in the state of your batteries if e.g. the passenger side is past its best it will drain the other battery and that's why it's usually recommended to change them in pairs.
If you get Dave to test them he will warn you that drop testing can finish a dieing battery off and if he does it at arms length it's because the last one exploded and covered him in acid!
