Press the on button a light will come on on the dash confirming it's active drive up to 30mph that's its minimum working speed the hold the stalk downwards, car should accelerate to the speed you want then let go, a dab on the brake pedal will disable it, you can lift the stalk up to resume the previous speed setting. Just play about with it you won't break anything
